New Centroid Acorn Control 3D Printed Case!
New downloadable case for Centroid Acorn. Link to download the case: https://www.thingiverse.com/thing:2872967
Miguel G. and I collaborated to make a 3D printed case for my version 3(Acorn 171025) Centroid Acorn. This case is compatible with Acorn 171025 and later. It's made in fusion 360. I've uploaded to my thingiverse the .f3d, .step and .stl file so you can change and adapt it to fit your needs!
https://youtu.be/WaK6ZS0Xnnw
- CNC Control System Serial Number: C8FD19F23AFF-0213180659
Re: New Centroid Acorn Control 3D Printed Case!
Nicely done!
Yes, very nice! Too bad it will be virtually impossible to produce on your typical fdm printer.
- CNC Control System Serial Number: many boards
Hi,
Don't pack the Acorn board in a too close case without proper cooling,
It will burn off !!
\PLData
It will burn off !!
\PLData
i printed one on my fdm printer. turned out pretty decent. i can post pics and info if anyone would like
Jeremy
Pittsburgh, PA
Pittsburgh, PA
Well, your printer is better than mine.
- CNC Control System Serial Number: 0503160222
I printed one of these cases in FDM and noticed a few little issues that I corrected for my build. I emailed Mary and I will upload my STL files on Thingiverse if anyone else wants to use them.
In FDM:
In SLS and painted:
More photos can be found here:
Thanks for all the hard work putting the 3d models together!
Bill
In FDM:
In SLS and painted:
Bill
Bill,
Did you ever upload your files to Thingiverse? I printed the base, but found that the standoffs are to low. How did the holes for releasing the catches work out?
I'd like to make it with a flat top so that I could do a color change for the logo.
Scott
Scott
Scott
- CNC Control System Serial Number: 985DAD429EE9-0926170118
Mary,
Ignore all the negative comments, I think you did a great job. As long as there is a little clearance in that case it should work perfect. You can touch y our Acorn after being on days and it is barely warm.
You made me put a 3D printer on the top of my toy list. ha ha
Russ
Russ
