Rigid tapping - Mill Intercon
Please see Acorn Rigid Tapping setup guide attached.
Acorn Rigid Tapping Setup for Mill and Lathe.pdf
(213.73 KiB) Downloaded 6 times
Rigid Tapping instructions and setup info for Mill or Lathe
- Acorn Rigid Tapping Setup for Mill and Lathe.pdf
- (213.73 KiB) Downloaded 600 times
Re: Rigid Tapping on Mill or Lathe
I was looking at the v4.10 release notes and I didn’t see anything (I think) that would be detrimental for me to go backward to v4.08. I have Mill Pro and am only experimenting with Intercon and rigid tapping. Can I just use the v4.10 update procedure and go back to v4.08 until the new, fixed CNC12 is released?
scot, let have a TV session today and i'll fix the issue. K
Re: Rigid Tapping instructions and setup info for Mill or Lathe
Thanks again for the help, Keith! Rigid tapping is operational here!
Great stuff Scot, glad you have it going your way!
I'm very interested in the thread milling process for the mill I'm building. I hope someone posts a video showing how it's done using Acorn/CNC12/Intercon.
Milton in Collierville, TN
Hi Milton,
Thanks, it is really cool how rigid tapping works! I hope to also try thread milling at some point.
