Centroid CNC12, CNC11 & CNC10 Manuals
diycncscott
Post by diycncscott »
updated by cnckeith 6-17-19
CNC12 Operators Manuals
CNC12 Centroid Operators Manuals
https://www.centroidcnc.com/centroid_di ... nuals.html
newbie Centroid PLC programming video series..
https://www.youtube.com/watch?v=7WiEJiQ ... i2WKIedQlQ
How to add a simple safety switch input to a PLC program
https://www.centroidcnc.com/dealersuppo ... ds/314.pdf
CNC12 PLC programming manual http://www.centroidcnc.com/centroid_diy ... manual.pdf
PLC Detective users guide.
https://www.centroidcnc.com/downloads/c ... kstart.pdf
MPU11/CNC11 Centroid Operators Manuals:
CNC11 v3.16 Mill Operators Manual
CNC11 v3.16 Lathe Operators Manual
CNC11 Windows 10 Setup Video:
https://youtu.be/Akmw8ak_TlM
CNC11 PLC Programming Manual:
http://www.centroidcnc.com/dealersuppor ... Manual.pdf
diycncscott
Centroid CNC11 Install Manuals - MPU11 systems
ALLIN1DC
centroid CNC11 ALLIN1DC Install Manual
http://www.centroidcnc.com/downloads/ce ... manual.pdf
Oak:
centroid Oak Centroid CNC11 Installation manual
MPU11/GPIO4D:
centroid MPU11/GPIO4D Centroid CNC11 Installation manual
http://www.centroidcnc.com/downloads/MP ... Manual.pdf
DC3IOB:
centroid MPU11/DC3IOB Centroid CNC11 Installation Manual
http://www.ajaxcnc.com/tech/downloads/m ... nstall.pdf
bloomingtonmike
CNC Control System Serial Number: 0916130849
Re: Circuit Board Manuals, Install Manuals, Operator Manuals
Post by bloomingtonmike »
Centroid Rotary Table - RT-150
RT-150_100111.pdf
(1.3 MiB) Downloaded 1526 times
Mikie in Bloomington IL
fyi.. all the latest Oak and ALlin1DC system schematic sets, installation and operator manuals are here.
http://www.centroidcnc.com/operator_manual.html
Is there an OAK velocity mode install manual like the one for the MPU11/GPIO4D?
yes..found on this page..http://www.centroidcnc.com/operator_manual.html
check out the oak schematics as well on same page
Re: Centroid CNC11 & CNC10 Operator Manuals
I keep most of my manuals on a tablet for reference and it's a lot easier to navigate if they have TOCs and hyperlinks. So, I went through the CNC11 lathe manual and added those. [strike]Still working on the Mill manual (although I have an older 3.14 version with links if anyone is interested.)[/strike]
{EDIT} TOC and Links added to 3.16 Mill manual attached
centroid-cnc11-v316-MillManual.pdf
(14.34 MiB) Downloaded 611 times
centroid-cnc11-v316-LatheManual.pdf
(10.55 MiB) Downloaded 521 times
Tom,
Thank you for the effort on this. The manual files are much nicer that way.
What software tool did you use to add the TOC and links?
Marc,
I used AutoBookmark from Evermap.
https://www.evermap.com/autobookmark.asp
It makes it easier, but still a lot of work.
Fredsan
Post by Fredsan »
Just saw this topic, and downloaded the milling manual with bookmarks.
Maybe you should post this also in the Acorn section, I expect many more Acorn users appreciate the bookmarks.
This makes searching the manual so much easier :D
