Tool Setting Options For Routers and Mills
Dan M
CNC Control System Serial Number: C8df84dfbdd5-0809181120
Re: Tool Setting Options For Routers and Mills
Post by Dan M »
bmilam wrote: Tue May 21, 2019 2:26 pm I am using the tool touch off and it works fine but when it goes back to the zero and then moves to where it is going to cut, the bit is pretty low to the surface during that move and I am constantly worried about hitting a hold down. How would I make the z retract higher to make that move? Hopefully that question makes sense
On my machine it's done in the V-carve file. I originally had mine set to 2" and bumped it up to 6", I'm pretty sure that you need to set the height in your Cam software.
bmilam
Post by bmilam »
Ok I use vcarve also. Never noticed that setting so I will check it out. Thanks that will be easy
Dan M
Post by Dan M »
bmilam wrote: Tue May 21, 2019 2:44 pm Ok I use vcarve also. Never noticed that setting so I will check it out. Thanks that will be easy
Go to the tool paths side and click on material set up it's at the bottom Home /Start Position.
slodat
Post by slodat »
What are you using for CAM?
In Vectric Aspire this is achieved with a couple of settings.
bmilam
Post by bmilam »
Thanks. I googled it and saw where it was. Was a setting that I had never messed with.
Slodat I am running vcarve pro
Dan M
Post by Dan M »
bmilam wrote: Tue May 21, 2019 5:00 pm Thanks. I googled it and saw where it was. Was a setting that I had never messed with.
I had the same thing happen when I first used the macro and vectric. When it dropped down and did a rapid about a half inch above one of my clamps it made me pucker up if you know what I mean. I realized real quick that the 2 inch default I had needed to be changed. I guess it's all part of the learning curve when we first start off.
Dan
GBCues
CNC Control System Serial Number: noneC120192
Post by GBCues »
Has anyone had a chance to test these custom macros under v4.16 or v4.18?
I always wait a few days after the initial release of a new version to see what, if any, gotchas might have slipped through. And now we are at v4.18.
Thanks for any feedback.
Gary
cbb1962
Post by cbb1962 »
The M6 I'm using works perfectly.
Clint in NW Arkansas
I'm using Clint's modified M6 version that I modified a bit more and it's working great with 4.18. Thanks again Clint for all your help.
Shawn
bmilam
Post by bmilam »
Hoping someone can help me out. I have been using Clint's M6 file for the moveable touchplate that came on the machine. I have it set up on Input 6 as probe tripped and it works perfectly. I wanted to add a fixed location touch plate to go along with it. I'm not exactly sure how I should wire it up. It is the UCONTRO Universal CNC Wireless Tool Setting Gauge Z Axis Height Setter https://www.amazon.com/gp/product/B01LY ... UTF8&psc=1. It has 4 wires, 5-24v, com, ov and probe. Where does the ov wire connect? What should I select for the input type on the fixed location?
