this on haas mini mill the haas setup uses a dc powered servo amplified 320 v dc input
same voltage connect to the other servo drives powering yaskawa ac servo
The larger amp powers the spindle . it think it 45 amp model . it wired to the spindle motor the label says low voltage
it only wire label no markings on motor.
Then theirs 2 small wires out motor that go to spindle encoder input on haas controller.
my question does a vfd duplicate this haas servo amp
the motor looks like a 3 phase motor is wired with 3 wire for power .
and the 2 small wire what are they . they wire to encoder input on controller
this last thing i try to figure out before purchasing parts for hickory build
i just need to make sure the vfd goa work
spindle motor and vfd
Re: spindle motor and vfd
post a link to a photo album created for this project with lots of photos of all the details.
Keeth once i start this i make video of all details put on my YouTube channel . there be lot detailed info and pics
