Centroid CNC12 v5.1 RC3 installer, Mill, Lathe, Router, Plasma, Acorn, AcornSix, Hickory, Oak, Allin1DC, MPU11
update. 4-5-24 RC#4 is here. https://centroidcncforum.com/viewtopic.php?f=67&t=9997
Centroid CNC12 v5.1 RC3 installer, Mill, Lathe, Router, Plasma, Acorn, AcornSix, Hickory, Oak, Allin1DC, MPU11 is now available.
download link is here:
https://centroid-support.filemail.com/d/xxiyeeiluifglcv
release notes outlining changes and additions from v5.08 is here
changes from RC2
39. Fixed graphic anomaly where homing direction indicator in the Wizard for the 4th axis would not stick on the selected M91/2 setting. This was a graphic only bug and did not affect the actual homing process.
40. Fixed RTG DRO position Graphic overlay anomaly for Lathes that have Turret axes being displayed as an axis.
41. Fixed G code Search bug where two tool changes would occur when searched for a line that had a macro on it which would result in double tool changes and other unexpected results.
42. Increased the CNC12 Bitmap graphics resolution to maximum, now all bitmaps (.bmp’s, jpegs and .pngs) look better in CNC12 than before.
43. Added Soft Limit control to Plasma and Laser THC position so now THC will not exceed a soft travel limit.
changes from RC2
Re: Centroid CNC12 v5.1 RC3 installer, Mill, Lathe, Router, Plasma, Acorn, AcornSix, Hickory, Oak, Allin1DC, MPU11
There seem to be something broken with smoothing in RC3. I have a special set of smoothing parameters for 3D relief and V-Carving, and with RC3, it's almost like it's stuck in exact stop mode. Motion is very jerky with a simple 45º ramp up, shallow dish, and 45º ramp down. V-Carving is not fluid in it's motion either. The "Smoothing On" indicator is showing, and I know that the desired smoothing parameters are set/saved. After reverting back to v5.08, all is well again. Two reports attached again, one from 5.10RC3 and one from 5.08.
Along with this, I think I noticed that MPG motion is jerky again like it was some versions back. I'm not positive on that, and would need to verify it again to be sure. https://centroidcncforum.com/viewtopic. ... 049#p81049
- report_780473842258-0115191645_2024-04-01_18-03-26.zip
- (1.64 MiB) Downloaded 5 times
- report_780473842258-0115191645_2024-04-01_17-51-57.zip
- (1.18 MiB) Downloaded 9 times
Scott
- CNC Control System Serial Number: A901313
I had this jerky smothing with an active switching of the 3D measuring probe without an error message from the system, I haven't tested this update yet.
thanks for reporting.Sword wrote: ↑Mon Apr 01, 2024 10:59 pm There seem to be something broken with smoothing in RC3. I have a special set of smoothing parameters for 3D relief and V-Carving, and with RC3, it's almost like it's stuck in exact stop mode. Motion is very jerky with a simple 45º ramp up, shallow dish, and 45º ramp down. V-Carving is not fluid in it's motion either. The "Smoothing On" indicator is showing, and I know that the desired smoothing parameters are set/saved. After reverting back to v5.08, all is well again. Two reports attached again, one from 5.10RC3 and one from 5.08.
can you post the g code program you are using so we can recreate here on our machines
Sword,
Was your 5.08 Install 32bit?
The 5.1RC3 is 64bit. Just checking if that's a difference between the two builds.
Here are two files, and a screenshot of the layout to show the datum point. Size is 15" x 6". You should notice it right away at the beginning of either file. v5.10RC3 will barely get up to 35ipm while jerking along, where v5.08 will get close to the commanded feedrate on the low to no detail parts and run smoothly. You can try my ad2_presets.xml from the report. Each file calls up the desired preset at the beginning.
I also tried running it with the standard Precision Router parameters with the same results in v5.10RC3.
I'm pretty sure that my 5.08 install is 64bit, as I have always chosen that one to download throughout testing. I checked, but couldn't find anything that stated that in the install.
If you need a short video of it, let me know.
- Daisies Finish 1mmBN.cnc
- (6.49 MiB) Downloaded 8 times
- Bottom Dish Finish 2mmBN.cnc
- (698.21 KiB) Downloaded 7 times
Scott
ok this one we are having trouble reproducing. about what line numbers on the job is it most prevalent?Sword wrote: ↑Tue Apr 02, 2024 3:11 pm Here are two files, and a screenshot of the layout to show the datum point. Size is 15" x 6". You should notice it right away at the beginning of either file. v5.10RC3 will barely get up to 35ipm while jerking along, where v5.08 will get close to the commanded feedrate on the low to no detail parts and run smoothly. You can try my ad2_presets.xml from the report. Each file calls up the desired preset at the beginning.
and a video would help as well.
Here's a video comparison. It's prevalent from start to end. I also tried all other smoothing parameters, and the result were similar for each.
Scott
Since these file were the only ones I've tried on 5.10RC3, I thought I better try some others that have many short segments, and I see that it affects many others as well. I have this file (starts at the 1 minute mark) https://centroidcncforum.com/viewtopic. ... 948#p20948 that has a lot of spirals and circles, and generally it would run like it does in that video, but with 5.10RC3, it just crawls and jerks along as if you were running exact stop.
Scott
holy moly, really does look like it is in exact stop mode. would have loved to see the cnc12 screen during the videos
