CNC12 V5.09 beta REV3 is now available for testing.
Release Notes
cnc12_v5.09_BETA_rev3_release_notes.pdf
(1.15 MiB) Downloaded 74 times
Download
https://centroid-support.filemail.com/d/wodgmdzgyaxwcuh
Re: CNC12 V5.09 beta REV3 is now available for testing.
thanks in advance for your efforts to avoid this!
lol...
Thanks Keith, that was funny.
Were you able to fix the fast/slow jog issue I reported to you?
Sword
Post by Sword »
:lol: D'oh!
As with the previous private beta, I'm seeing that the Reset logic is behaving badly. Upon power up, it goes straight to "Reset OK", with the NoFault output immediately enabled. If you exit without hitting Reset to "Tripped", and restart CNC12, it starts back up with "Reset OK", but with NoFault output disabled. Reset needs to be cycled once to get it working right and you need to exit with it "Tripped" for it to restart as tripped, but upon the next power up, you're back to the initial "Reset OK/NoFault" enabled.
Report is just the initial machine specific config with no VCP edits yet.
report_9884E39427E5-1206170338_2024-02-14_20-27-15.zip
(894.04 KiB) Downloaded 18 times
Scott
Reset Logic was always different in Acorn than in Acorn6.
But since I cycle reset after start up, I did not mind it.
Sword
Post by Sword »
Hmm...if that's the case, that's a bit of feature creep that I don't care for. Don't really want everything powered up by just launching the software, and having a possibility of a false condition of the button at some point as well.
Scott
ShawnM wrote: Wed Feb 14, 2024 9:40 pm Thanks Keith, that was funny.
yep
suntravel wrote: Thu Feb 15, 2024 4:04 am Reset Logic was always different in Acorn than in Acorn6.
just an omission with this build, we will be returning to reset tripped on boot up for Acorn
cnckeith wrote: Thu Feb 15, 2024 4:03 pm
yep
Awesome, thank you and thanks to the entire team at Centroid.
fyi. we found a wcs related issue with rotary graphics, (does not effect cutting) we'll have a _rev4 out soon with the fix.
