Centroid CNC12 v5.07 rev16 is now available for download and testing.
download link
https://centroid-support.filemail.com/d/nujovytbjxuexgh
changes since rev15
75. PC Tuner: The NCnetic Notepad++ Gcode viewer/editor plugin is now included with the CNC12 installer. The PC Tuner now will install this nice plugin for use with Notepad++
76. Fixed bug where Oak/Allin1DC/Hickory/MPU11 systems would not update the distance to go DRO readout for a slaved axis if the slaved axis had a label.
77. Fixed bug where M200 wasn't displaying the formatted message for AcornSix
78. Fixed bug where Lathe RTG menu DRO showed X coordinates in Z location and vice versa
79. Fixed bug where two outputs could be assigned to OUT2 in the Wizard if PWM was enabled
80. Updated the "System Test Not Passed" message on mainscreen with graphics and hyperlink to TB 327
81. Fixed bug where G-Code display would not update with a newly posted Intercon job
82. Created the Hickory absolute encoder paired axis gantry alignment/squaring procedure document.
Centroid CNC12 v5.07 rev16 is now available for download and testing. download link
