CNC12 v5.1 RC#6 Mill, Lathe, Router, Plasma RC5 now available for download and testing.
Models: Acorn, AcornSix, Hickory, Oak, Allin1DC, MPU11
Download link
https://centroid-support.filemail.com/d ... 63393e70b5
changes from RC5
Fixed M115 not stopping when a TT is tripped when a NC Probe without a detect is connected and detect probe via tool number is turned on
usinart
Re: CNC12 v5.1 RC#6 Mill, Lathe, Router, Plasma RC5 now available for download and testing.
Post by usinart »
Here the new report after the installation of 5.1 cnc12.
At this time didn't test the system for trouble .
Is there something rongh with the report ?
do understand that line? in previous message.
(Fixed M115 not stopping when a TT is tripped when a NC Probe without a detect is connected and detect probe via tool number is turned on)
report_E415F6F138CC-1119204064_2024-04-17_10-14-08.zip
(900.42 KiB) Downloaded 4 times
usinart
Post by usinart »
Ok as this moment nothing as change .the axe that are plugin are moving as soon the power arrive.
need help .
thanks
usinart wrote: Wed Apr 17, 2024 10:26 am Ok as this moment nothing as change .the axe that are plugin are moving as soon the power arrive.
need help .
thanks
is this the sigma 2 system? need photos and more information to help.
usinart
Post by usinart »
SIGMA 2 SYSTEM ???
acorn centroid with delta asda-b2 wiring system problem .
went cnc 12 and acorn is open , and I power up the the motor drive the x and z (only 2 axes are powered up for now) the motor start moving by it self.
What rough with acorn???
usinart wrote: Thu Apr 18, 2024 12:48 pm SIGMA 2 SYSTEM ???
hi,
disconnect all but one delta drive from the Acorn.
enter delta asda software and perform a factory reset of the parameters.
confirm factory reset.
enter acorn delta parameters
confirm correct parameters
jog motor with asda software.
power cycle delta drive.
then test with Acorn
https://centroidcncforum.com/viewtopic. ... 724#p86724
