CNC12 v5.1 RC#5 Mill, Lathe, Router, Plasma RC5 now available for download and testing.
Models: Acorn, AcornSix, Hickory, Oak, Allin1DC, MPU11
Download link
https://centroid-support.filemail.com/d/awgpjertgujoqmq
Differences from RC4
- Added to the Wizard Tool Touch Off device setup menu choices between the two main methods of measuring tool height offsets. Reference Tool method OR Z ref = Z home method.
- Added to the Wizard Touch Probe setup menu the ability to enable/disabled the new Probe Protection feature based on Tool number.
cnc12_v5.1_release_notes.pdf
(864.44 KiB) Downloaded 28 times
Houseman303
CNC Control System Serial Number: A901313
Re: CNC12 v5.1 RC#5 Mill, Lathe, Router, Plasma RC5 now available for download and testing.
Post by Houseman303 »
How would that work for the oak since no wizard is possible. Is the entry in the parameters enough?
dpascucci_support
Post by dpascucci_support »
Houseman303 wrote: Wed Apr 10, 2024 4:34 am Added to the Wizard Touch Probe setup menu the ability to enable/disabled the new Probe Protection feature based on Tool number
An additional bit was added to the bit-mapped parameter 3. "Add 16: Probe Protection based on Tool Number"
Domenic
Houseman303
thanks
Yes, (the wizard sets cnc12 parameters).
any new parameters will be added to the operator manual with description on how to use them.
side note, if you wonder what parameter/file the wizard is setting press ALT P on any screen and they will be displayed.
avp
CNC Control System Serial Number: E062346A1C67-0716214939
Post by avp »
Trying out 5.1 RC5 today.
Auto Z to plate not working.
I have a NC TT device setup in the wizard as mechanical, input state when triggered=open
This shows to be working correctly in the diagnostic screen, however when using auto z to plate it doesn't work. Z keeps moving until it triggers the over travel switch in the device that I have tied into my estop. It does indeed trigger the input LED though.
Bill
Allin1Chris
Post by Allin1Chris »
avp wrote: Wed Apr 10, 2024 3:11 pm Trying out 5.1 RC5 today.
Bill
report_E062346A1C67-0716214939_2024-04-10_15-03-46.zip
Hello,
Appreciate the report, looking into it this does appear to be a wizard issue. A quick work around is to set Parameter 406 = 0 or go into the wizard and set the Probe to Closes when tripped instead of Open (even though you do not have a probe). Should be resolved in the next version.
Centroid PLC Tutorial Videos
avp
Post by avp »
Hello,
Ok, setting Par 406 to 0 did the trick. Wizard writing issue I guess.
Thank you
Bill
avp
Post by avp »
Character display problem now. Same version 5.1RC5
avp wrote: Mon Apr 15, 2024 5:03 pm Character display problem now. Same version 5.1RC5
thanks, please post a fresh report.zip so we can see your various selections (RTG on/off) etc..
