CNC12 V5.08 Feedrate is controlled by rapidfeed control
RC-Lights
CNC Control System Serial Number: 0008DC111213-1005220061
Post by RC-Lights »
hi guys,
today i had a really strange mistake. i did some easy cuts for figure out how to produce better surface in a radius. ( see other thread later ).
attached you can find the g-code created 100% in Intercon without any manual modification.
i wondered, because the feed while turning was really slow. and also the time calculated was around 30sek, the real time needed was around 2minutes.
so i double checked the feed status and it was 100%. My rapid feed was on 25%, because new programm.
after checking the g-code i did the programm again and tried to adjust rapid feed. and voila, the turning feed changed with changing the rapid feed, but display on the monitor stayed 100%.
after restarting AcornSix everything works fine, so i cannot film it.
maybe you have an idea for the reason.
kind regards,
Michael
Test_kegel.cnc
(1021 Bytes) Downloaded 1 time
report_0008DC111213-1005220061_2024-05-08_15-02-42.zip
(1020.15 KiB) Downloaded 1 time
Re: CNC12 V5.08 Feedrate is controlled by rapidfeed control
Not sure if I remember right, but this should be fixed in current 5.1
