sounds good. the tool library in cnc12 is going to get a make over in v5.2 for mill and router
1st stage of this make over will be in v5.18 which will be a router only release.
CNC12 v5.1 RC7 (which is build #17806) went up last night with these fixes and improvements
Re: CNC12 v5.1 RC7 (which is build #17806) went up last night with these fixes and improvements
- CNC Control System Serial Number: A901313
I hope the new tool table is in one window and not in 2 and therefore not 2 files. In principle it would be enough for me. And could automatic capitalization be deactivated? I generally always have uppercase letters on the PC because of Cam and then in cnc12 it is lowercase
That is not fair, I have no router yet
Tool Lib is for me less a problem than not having second independent spindle with Acorn6 and no G2/3 with XY plane on the lathe...
yeah that is still on the list, been doing a big router rework which is almost done, then hickory wizard, hickory plasma, then circle back around to second spindles, second z axis, arcs in xy plane for lathe etc..
Yes I know, you have to focus on the needs for the majority of customers, I would do the same
- CNC Control System Serial Number: E062346A1C67-0716214939
Looking forward to testing the router rework.
Bill
Bill
very close, i estimate mid next week for public beta v5.17 Acorn CNC12 Router.
Utils button on the VCP in Lathe software is pointing to C:\cncm.... it should be C:\cnct to work
