v5.07 rev 15 beta download now available.
https://1016.filemail.com/api/file/get? ... 9989ef1a64
changes from rev14
- fix for rapid override control with G99 in Lathe.
- added Plasma Profile folder full of material profiles specifically for Hypertherm 45XP cutter
- Implemented Parameter 496 to set USB com port for future USB connected hardware such as Future Centroid operator control panels
updated draft release notes attached.
v5.07 rev 15 beta download now available. updated draft release notes attached.
- cnc12_v5.08_release_notes_rev15.pdf
- (1.05 MiB) Downloaded 69 times
Re: v5.07 rev 15 beta download now available. updated draft release notes attached.
According to customer:
1) Rapid Override issue with G99 feed-per-revolution moves is fixed. Thank you.
2) Lathe X/Z axis cross-up on Current Position mini DRO, on Runtime Graphics screen, is not yet fixed. DRO still shows wrong axis positions.
thanks for the feedback.
we will fix #2 right away.
