I'm seeing slow jogging on this version...
When using the jog buttons on the VCP positive moves work at full speed, but negative moves on XYZ seem to go at half speed... Is this a new setting I'm not aware of?
Report attached.
Slow Jogging
Re: Slow Jogging
Check the axis config in the wizard or setup/config/machine/jog. There's a new separate fast jog +/- setting.
Scott
Re: Slow Jogging
There sure is! I missed that one!
One thing I did notice is that with the pendant it jogs fast in all directions.. I like that just fine but it might be worth noting that the VCP and pendant jog behavior is different.
