PLaying with plasma last night and went to create in intercon and couldn't find it. Saw today its listed as FUTURE.
I am a big fan of Intercon. Hope plasma gets it for sure. A lot of why I like centroid.
Mikie
Plasma Intercon now available for use
- CNC Control System Serial Number: 0916130849
Mikie in Bloomington IL
Re: Intercon
we are working on it
Re: Intercon
its ready for you guys to start using!
here is version you can use offline. (offline = another Windows PC other than the CNC PC)
https://www.centroidcnc.com/centroid_di ... taller.zip
Re: Plasma Intercon now available for use
Though not having a plasma cutter, was curious to test out the new Intercon.
WOW this is great.
WOW this is great.
I'm thinking it will also work pretty well for a waterjet.
I am wondering why you need a PP / CAM system for plasma?
I made this with nesting in Intercon, took only 4min and I am not used to the new Intercon.
DXF import and SVG import works well, if you have to construct more complex cuts.
Those look like the drain covers I’ve been cutting for the last few days from 1/4” aluminum.The latest, larger drain cover has 128 one inch holes. Does intercon make it cut any faster?
I’m upgrading software this weekend now that the job is complete and will have a look at the new Intercon. I’ll admit, I’ve never even used it before.
They were indeed my inspirationShawnM wrote: ↑Sat Sep 03, 2022 9:15 am Those look like the drain covers I’ve been cutting for the last few days from 1/4” aluminum.The latest, larger drain cover has 128 one inch holes. Does intercon make it cut any faster?
Your Plasma is some kind of teasing me to have one also
And who do not need drain covers?
But i do not think it makes cutting faster, but maybe speeds up setting up new parts
..... or prevent extra cost to get a SheetCAM license.
