All my reports get Tripped l can't home
- Plasma CNC Controller: Yes
My machine runs all over sudden it stops. When l restore report it get tripped and can't clear so l can't home. What's it happening. How can l buld a trusted working report and save it.
Re: All my reports get Tripped l can't home
when you get the machine running the way you like it. use the create report button in the util menu.
save the report to to folder on your desktop. name it something like "good working report"
then if your config gets messed up or you install a new PC you can use that report on the SAME version of CNC12 to reconfigure it just the way it was the day you made that report.
why did you think you had to restore report in the first place?
