Hi
Retrofitting a 1.5x3m Plasma cutter with the Acorn system and was wondering where I would be able obtain setting for the Profile Manager.
Also are the figures in the profile manager just a conservative starting point, and one needs to tweak those figures for their machine ??
Hypertherm PowerMax 125
Re: Hypertherm PowerMax 125
Will Attach the Powermax125A Profiles Shortly. Profiles by default are Powermax85A
I have Arranged this profiles folder with the Hypertherm PowerMax 125 specific profiles.
Just download the attached profiles zip folder. Extract the (profiles) folder from the zip folder.
The attached profiles folder will replace your current profiles folder.
You profiles folder Path is C:\cncm\resources\plasma\profiles
Hope this helps.
Hope this helps.
- profiles.zip
- (308.72 KiB) Downloaded 44 times
- CNC Control System Serial Number: 0035FF8A54E0-0610203404
Hey Joey
Thank you so much, very much appreciated
