Attached is a new report.
I checked Windows zoom level. It is on 150%. I set it back to 100% and the G code display came right. But everything else in Windows is too small to see or press with my fat fingers! So, I would like to run Windows at 150%. This is a full touchscreen only setup, no mouse or keyboard. Has worked great for years. The rest of CNC12 works fine at 150%
Another question I have is why are the new G codes inconsistent with the rest of CNC 12? The font is different. And the heading is black text in a white block, whereas every other heading is plain blue text. The text is not vertically centered in the solid blocks.
Some time ago, I spent four years working writing high performance manually drawn GUI code for Windows. So unfortunately, it is an area I am a bit picky about.
This screen shot shows the entire screen at 150%
This one is at 100%.
CNC12 5.08 Upgrade Issues
Re: CNC12 5.08 Upgrade Issues
- report_0008DC111213-1214201066_2024-01-19_18-44-46.zip
- (2.81 MiB) Downloaded 20 times
the way the active g code is displayed in cnc12 was re written and looks like it was not tested with windows set to 150% test size.
i'll see what we can do.
Any updates on this?
