Homing A axis
Houseman303
CNC Control System Serial Number: A901313
Homing A axis
Post by Houseman303 »
How do I set the rotation axis to G53 A0 when the home switch is at 10,731 degrees in cncm.hom?
Re: Homing A axis
If you mean to ask, "how can I make the current position of the A axis become machine zero", the answer is "M26/A"
If you mean to ask, "how can I make a position that is -10.731 degrees away from the current position become machine zero (so that the current position shows as A+10.731)", then the least confusing answer is to move that distance (e.g. "G0 G91 A-10.731") then do "M26/A" after it gets there.
There is also a variant of M26 that lets you set the axis to a non-zero position, but it uses encoder counts, so you have to roll your counts/degree value into the code. That tends to be more confusing to readers.
Houseman303
Re: Homing A axis
Thanks, that's how it worked. I tried the one from the Cnc12 manual with the L command and the encoder value and failed.
