100 Step MPG - reverse dial direction
Posted: Tue Jun 06, 2017 11:16 am
by Jay
Hi, This may be an 'out in left field' question, but is there way to reverse the dial direction on the Ajax supplied MPG.
My Bridgeport S2I2 has jog sticks and a matching MPG that mimic table movement rather than head movement. The MPG of which to be replaced by the Ajax 100-step MPG. However the old MPG and new one rotate in opposite direction to achieve +/- movement. I'd like to reverse the direction on the 100-step to keep it matched to the original MPG. Is this a software change, or something like a A/A' B/B' swap?
Jay
Re: 100 Step MPG - reverse dial direction
Posted: Wed Jun 07, 2017 8:30 am
by Centroid_Tech
Jay,
Unfortunately, there isn't anything that can be done in the CNC software to reverse the direction of the MPG encoder signals. You will have to physically swap the A signal with the B signal and the /A signal with the /B signal.
Posted: Sat Jun 10, 2017 9:10 am
by Jay
Thanks, I'll give the A>B and A/->B/ swap a try see how it works.
Jay
Posted: Tue Aug 01, 2017 8:52 pm
by Jay
Whoop's!
..just noticed the new Allin1dc manual shows two different ways to wire up the MGP - check out the A/A+/B/B+ connector pin locations on page ~115 ( the ALLINONEDC Cables Schematic) - then compare it to the ALLINONEDC Connectors on page ~139
so.. which is the right way - so I can reverse it for my application.
Jay
Posted: Wed Aug 02, 2017 10:41 am
by Centroid_Tech
I am a little confused. Attached are the photos from pages 115 and 139 of the ALLIN1DC installation manual and the encoder pinout on both pages are exactly the same. The only difference is that on one page the signal's compliment is designated with a backwards slash, \, while on the other page it is designated with a dash, -. Please clarify where you are seeing the signal incompatibility.
Posted: Wed Aug 02, 2017 12:33 pm
by Jay
Yeah - the pages numbers were confusing. I was using the pages numbers from the PDF Reader, rather than the doc directly.
Here's the screen shots
Posted: Wed Aug 02, 2017 1:31 pm
by Centroid_Tech
I apologize. I was looking into the encoder signals rather than the MPG encoder signals. The signals on the ALLIN1DC board layout are the correct signals. Pin 1 of the MPG connector starts with +B then -B then +A then -A.
Posted: Wed Aug 02, 2017 2:07 pm
by Jay
Awesome! - thanks for the clarification!
Jay
