Drag Plot Explanation
Posted: Mon Jan 11, 2016 12:56 pm
Can anyone explain what the Drag Plot graph represents and how to interpret it?
This is what I have learned so far.
The red horizontal lines indicate the bounds acceptable limits for the machine as it is currently configured.
The graph displays a graph of the motor pid out/current used over the distance of the axis.
A "U" shape graph shows that the ballscrew is not aligned with the axis movement. stuff like that is hard to tell without it.
Most this information came from cnckeith. Thank you cncKeith!
It looks like the graphs X axis is the distance moved.
I think the graphs Y axis shows the amps used to move the axis.
Why are there 2 different graphed lines on the X axis? I am guessing one is for movement in one direction and the other is for movement in the the opposite direction.
What is the yellow line? I am guessing it is actual amps used to move the machine axis. But on my Z axis (Which comes up with no excess drag) The yellow lines are above the red lines for mach. movement in one direction and below the red line in other direction. ??? The seems like the power to move is greater than the red line which indicates power limits. ??
What I am asking is a explanation of what this all means.??
