We received a crate monday (02/06/2023) with the M15 Upgrade, its an ALLIN1DC with M400 console. I have plugged in all the wires from the ALLIN1 to the Console. All the Encoders and Motors are wired in too. When I power it up from the original Mag Box (turn the switch), I can see/hear the ALLIN1 power up, and the M400 (NUC) powers up, fans are running too. The Display flashes a message that appears to say the display is not connected. I dont have any documentation, nor can I find any that tell me what the message means, or how to verify the wiring in the M400. Can anyone help?
There is one ribbon cable that is not connected to anything, does that need to plug into something?
Thanks-
Nick
Brand New M400 (M15 Upgrade) on Vectrax
- CNC Control System Serial Number: A901226
Re: Brand New M400 (M15 Upgrade) on Vectrax
ribbon cable does not plug into that port. the tiny pc board with the button is for setting up the horizontal and vertical position etc.. the screen setup was done at Centroid so no need to connect to it, the board is included but not connected just in case the LCD display needs to be adjusted again.
I'll have liviu contact in the am and talk you thru getting things running. send him email with your contact info at diysales@centroidcnc.com
Based on your photos, everything I can see is connected correctly. I don't see a photo of your power supply connections, but I do see the NUC power supply is plugged in. The display on the screen means the monitor is powered but has no input signal. Does the Power LED on the NUC come on when you turn on machine power and the screen comes on? The NUC is already set up in the BIOS to come on after power is detected, the Console Power cable plugged in is the only user connection required for the screen, NUC, and fan to function. If you can grab a photo of the power supply I can double check that side, but there is nothing that would need to be modified as that is also pre-wired.
I will give you a call at 9am your time, or you can call me at your earliest convenience (ext. 117).
Thank you for your help, turns out the NUC was not powering up, I checked connections and pressed the power button on the NUC, it is now on!
I'll work on setting up the machine now.
