TD-4242
Posts: 27 Joined: Sun Apr 12, 2020 11:03 am
CNC Control System Serial Number: KI04039
Post
by TD-4242 » Sun Nov 14, 2021 2:52 pm
I have old Yaskawa DC motors:
UGHMED-06 GG1XX
cont. inst.
kW 0.51 - 2.57
kg-cm 50 - 250
rpm 1000 - 1000
Volts 113
Amps 6.5 - 32
with the defautl:
it works but makes a lot of noise while holding.
I'm going to try manual tuning but was just wondering if there's maybe a good starting point other than the default that may help me out.
https://photos.app.goo.gl/Psw7ungT3tukJoit6
TD-4242 on Wed Nov 17, 2021 5:52 pm, edited 1 time in total.
Posts: 3877 Joined: Wed Mar 24, 2010 5:48 pm
Post
by cncsnw » Sun Nov 14, 2021 3:40 pm
Try:
Kp = 0.6
Ki = 0.001
Kd = 1.2
TD-4242
Post
by TD-4242 » Sun Nov 14, 2021 4:04 pm
While playing around I was finally able to get it so it was only making a very small amount of noise at:
Kp 0.3
ki 0.0008
kd 0.3
This was after a lot of trial and error. Not sure if this is good or bad though, as this is the first time I've ever tried doing something like this.
TD-4242
Post
by TD-4242 » Sun Nov 14, 2021 6:47 pm
seems like these numbers aren't great either as it is still a bit shaky finding zero.
Post
by cncsnw » Sun Nov 14, 2021 7:30 pm
I evidently missed where you posted a Report, or told us what type of control system you are using.
I am guessing that you settled on an Allin1DC, and are therefore using torque-mode control (the only kind that Allin1DC does).
If instead you opted to use an Oak control and the old Yaskawa drives, in velocity mode, then the approach may be very different.
There is no guarantee that you will find a satisfactory middle ground between too noisy/jittery, and not responsive enough. Since these motors are generally unexplored territory, you probably know as much about tuning them as anyone.
TD-4242
Post
by TD-4242 » Sun Nov 14, 2021 8:56 pm
Yeah, sorry about that I was just asking if anyone had any known numbers for these specific drives.
This is an Allin1dc. I'll run a report and upload it.
TD-4242
Post
by TD-4242 » Sun Nov 14, 2021 9:39 pm
This is just the initial bench testing to insure that I can get things to work before doing the cabinet layout and taring down the old Acroloc.
Here is the bench test environment:
Here's a video of the noises this drive is making although youtube compressed and washed out the audio:
VIDEO
TD-4242 on Mon Nov 15, 2021 9:58 am, edited 1 time in total.
polaraligned
Posts: 231 Joined: Mon Feb 07, 2011 8:03 pm
Post
by polaraligned » Mon Nov 15, 2021 9:29 am
You will never be able to tune them correctly on the bench. Mount them up and then run the tuning routines. Even then it can be a bit hard for the inexperienced, but post any problems and someone should be able to give you guidance.
TD-4242
Post
by TD-4242 » Mon Nov 15, 2021 8:43 pm
Thanks, working slowly through it I didn't want to tare down the current machine until I had a little more knowledge on the processes. I'll take the fact that I can move the motors as my current success and move forward. Have a bunch of stuff on the way for me to start working on cabinet layout.
Posts: 9915 Joined: Tue Mar 28, 2017 12:01 pm
Post
by martyscncgarage » Wed Nov 17, 2021 5:09 pm
Bill, your video seems reasonable for a motor on the bench with no load.
Its good you can control the motor at this point.
If you get in jamb, I have 3 Centroid 29 in-lb. motors.
P.S. Always get in the habit of generating and posting a fresh report when you need help.
