I am knee deep in a retrofit of a millport 1630.
Soon I will make a new cabinet skin for my 15" Eli touchscreen monitor/display.
Thinking that Ajax pendant sure looks awesome. Is there a sheet with e cutout and mounting hole specs I can use when I design my skin?
Who is using that pendant with Mach? I own a mach license for my castcnc joes mill and will use it with my millport at first. On my Joes I use an xbox with mach. I actually like that.
Still waiting to verify my heidenhain encoders work. Hopefully this week.
Ajax Pendant internal mount size and who uses it with Mach
- CNC Control System Serial Number: 0916130849
Mikie in Bloomington IL
Re: Ajax Pendant internal mount size and who uses it with Ma
Are you looking for the pendant dimensions or just the jog panel part? The pendant is designed to be hand-held (and movable with a 16' cable) and is equipped with with magnets on the back so it can be placed on any type of ferrous material.
Was thinking I wanted the panel dimensions so I could build it into the enclosure like the m400 setups. Do you have a sheet showing mechanical drawing of it?
Having it magnetized to the side of the monitor box might be the best of both worlds too.
I have attached dimensions for the front panel cutout.
- front panel cutout rev.B.pdf
- (14.83 KiB) Downloaded 194 times
Jog panel is a must. You will not regret it.
OK, ordered the pendant and centroid software.
