**Resolved** parallel port
i cant make the servos move, did i need a computer with parallel port or only ethernet connection, thanks
Re: parallel port
Can you give us a little more information about your setup? Do you have your system serial number or system ID number? Are you using Centroid or Mach3 software? Our currently shipping MPU11/ALLIN1DC systems communicate via Ethernet cable.
Re: parallel port
ajaxliviu wrote:Can you give us a little more information about your setup? Do you have your system serial number or system ID number? Are you using Centroid or Mach3 software? Our currently shipping MPU11/ALLIN1DC systems communicate via Ethernet cable.
i buy dc3iob with mpu11, my desktop is win 7 32 bit without parallel port, i tray to use mach 3 softwere to run a supermax mill , the DF led in the dc3iob is off ,
were can i see the serial number?
when i push the e stop in the monitor with the mause doesn't ear the click relay sound in the dc3iob, i can read the encoders values when i move the table in the mach 3 sofwere, but cant run the servos, i use my old transformer and capacitor and i have 118 vdc in the d3iob
thanks.
Re: parallel port
Do you have the Ajax Mach3 Plug-In installed and configured? You can download it here if you don't have it. Also make sure you have Microsoft .Net 3.5 installed as well. What step are you at in the installation manual?
Re: parallel port
ajaxliviu wrote:Do you have the Ajax Mach3 Plug-In installed and configured? You can download it here if you don't have it. Also make sure you have Microsoft .Net 3.5 installed as well. What step are you at in the installation manual?
yesi have install it, i change my computer with an older one with win xp and have parallel port the df led turn on and the relay start clicking, when i tray to move the servos i have axis position error and full power with out motion, the encoder values go higher when i facing motor and turn ccw in my pid,
question?
can i connecct the servos dirct to dc3io or i need other servo driver betwen servos and dc3iob, thanks
Re: parallel port
The System ID number is on the MPU11 itself. Did you buy the encoders from us? What value do you have for your "CountsPerRev" and what line resolution are your encoders? Please see section 7.7 for wiring motors and motor power. The motor power will need to be wired from your servo power supply to the DC3IOB. And the same with your motor power cables to the DC3IOB. There is schematic on that page that further illustrates the connections. The DC3IOB is the DC Drive in the setup.
Re: parallel port
Do you have your limit switch inputs closed, jumpered, or defeated?
If not, the axes won't move.
Re: parallel port
ajaxliviu wrote:The System ID number is on the MPU11 itself. Did you buy the encoders from us? What value do you have for your "CountsPerRev" and what line resolution are your encoders? Please see section 7.7 for wiring motors and motor power. The motor power will need to be wired from your servo power supply to the DC3IOB. And the same with your motor power cables to the DC3IOB. There is schematic on that page that further illustrates the connections. The DC3IOB is the DC Drive in the setup.
yes i buy the encoder from you dynapar brand 2000 PPR/0 5vl 1/2" 6"cb for each axis
i have a 5 turns per inch ballscrew belted 1.5 :1 60000 count per inch
the mpu11 key a 032911028 date 3/23/11 label QC253 code bar C21073
tray to move sem motors 30m4-59
i already have jumped the limmit switchs and have a e stpo button in use
my connection from the dc3iob are correct when y try to jog, the table move fast and the e stop in the mach3 softwere goes on and x,y,z, axis position error appears and full power without motion i already try switching V+ andV- at the dc3iob motor outputs, i try reversing the encoders and do the same
i keep trying to faind answeres in the forum
thanks appreciate your attention
Re: parallel port
crfa777 wrote:ajaxliviu wrote:The System ID number is on the MPU11 itself. Did you buy the encoders from us? What value do you have for your "CountsPerRev" and what line resolution are your encoders? Please see section 7.7 for wiring motors and motor power. The motor power will need to be wired from your servo power supply to the DC3IOB. And the same with your motor power cables to the DC3IOB. There is schematic on that page that further illustrates the connections. The DC3IOB is the DC Drive in the setup.
sorry the key A is 0329110328
7.5 motor turns per inch
thanks
Re: parallel port
Hello,
Please take a report from the system and send it to tech@ajaxcnc.com.
To create a report, insert a usb stick then select F7-Utilities -> F7-Report. Use the arrow keys on your keyboard to highlight the usb drive, press enter and then press F10-Accept.
Please send us just the report.zip
