can i run mach 3 softwere with windows seven computer? i have DC3IOB AND MPU11crfa777
**RESOLVED** windows seven
Re: windows seven
It should not be a problem since you will not require the 32bit Parallel port drivers for the MPU11. I have tested a few systems during my setup including Windows Server 2003 32bit and Windows 7 64bit and each has run Mach and the Ajax plugins without issue.
