M5
M5
Cant seem to get my spindle brake to pulse after a M5 command. Have tried SetMasterOutput(13,1) in M5 macro but nothing. Is that the correct command from a macro to trigger a modbus output on ajax board? Thanks
Re: M5
Riley,
That will set output 13 -just make sure you are not stepping on that output in any brains. You may also want to setup a brain so you can monitor whether or no Mach thinks the output is on.
Use the Output as the input to a rung in a brain and then set a user LED (say LED #1200) to reflect the state of the output. Than use the "watch brain" option under "Operator"
Don't forget to enable and reload all brains.
