I installed the brain that Scott wrote. When I touch the shift key the table stops like others on the board have mentioned. Has anybody got this to work yet?
Fast Jog
- CNC Control System Serial Number: (214110103)
Re: Fast Jog
I am having the same problem. I loaded the brain and not only does it not work it causes the jog to keep going by itself! Good luck in your search for a solution!
