Probing
Probing
How is a probe set up and used?
Re: Probing
I have a Wildhorse Innovations probe, I need information to install and operate it.
Re: Probing
The pinout is provided on the MPU11 schematic.
Using and configuring a probe is covered in the Ajax Mach Operators manual.
A probing macro -M931 is provided with the Ajax Mach plugin. Information on using it is also provided in the Ajax Mach Operators manual.
Re: Probing
The manual states that I can use the high speed probe input channel 481. What pin number would that be. It is not listed in the MPU11 I/O Map.
Re: Probing
I connected the probe, trying all of the probe inputs on the MPU schematic. MPU11 diagnostic screen comfirms contact. I entered the number into plugin configuration per Ajax Mach Operators manual. Set ports and pins. Restarted. Mach doesn't see probe input. What steps should I take next?
