Linux to windows
- CNC Control System Serial Number: (0616102337)
Linux to windows
How can I put the centroid program on a Windows computer instead of linux?or should I keep and learn how to use linux?
- report.txt
- (92.34 KiB) Downloaded 89 times
Re: Linux to windows
Hello. There are several upgrade paths. looks like you are running a cpu7 isa card with CNC10 software from the report.txt file (thanks)
if you want to run windows the system will require a new CNC CPU card that uses the ethernet cable to communicate with the CNC PC rather than plugging into the motherboard ISA slot like the CPU7 card does. here is a link to more info on the legacy upgrade path to MPU11/ and Windows 7 based CNC11 or now available Windows 10 based CNC12. http://www.centroidcnc.com/downloads/mp ... cy_add.pdf
