I have found several good macros for Z axis touch plates BUT
I have a CNCrouterparts (Avid) 3 axis touch plate that works with Mach 3/4 using their
supplied XML file, and would like to use it with my Acorn CNC12 v4.18 controller.
Has anyone created a 3 axis (XYZ) macro or can lead me down the right path?
Any help would be great
3 Axis Macro Needed for Touch Plate
Re: 3 Axis Macro Needed for Touch Plate
Like this? I only use it for XY (inside or outside corners), but could be use for Z as well.
https://drive.google.com/open?id=1Jif-- ... _OR4PY5Qco
Scott
Yes! Not exact but very similar.
Would you share your macro
Sure, but I won't be able to grab it until Thursday morning.
Scott
Here ya go. Read through and tweak to your needs.
- XYZeroPlate.mac.mac
- (2.42 KiB) Downloaded 232 times
Scott
Thank you.
Much appreciated!
John
Much appreciated!
John
