How to change Centroid CNC12 Color scheme and share a custom CNC12 color profile with another CNCPC or user.
After you use the Color picker to create your favorite color scheme, navigate to cncm\resources\color and attach the .xml file to your post.
and then for others to use your custom color profile .xml file all they have to do is download and copy the .xml file into their cncm\resources\color folder and start the color picker and that color profile will show up in the list!
Note: the color profiles xml files are also included with a report.zip file so you can also simply post a fresh report.zip from your system as well.
Change the on screen colors of CNC12 with the Color Picker app.
