Nice workaround, but the problem that #25102 is always -1 is not solved.
On my lathe #25108 is working fine with the Index from the spindle encoder.
Since you also have a working encoder now, can you test if #25108 is set to a value other than -1 after one turn of the spindle?
AcornSix - Zri Homing with linear scales
- CNC Control System Serial Number: 0008DC111213-1005220061
Re: AcornSix - Zri Homing with linear scales
Hi Uwe, good Point. I checked it and 25108 is working as supposed, all other axis are always -1.
In this case it looks like Acorn6 is handling the encoder input if a scale is setup for an axis differently opposed to a rotary encoder for the spindle.
It would be nice if someone from Centroid could check this out.
