Wireless MPG Frequency
I am looking to use a different antenna on the USB transceiver for my Wireless MPG. Can someone tell me the operating frequency for the unit. 433Mhz, 900Mhz, 2.4Ghz...?
Re: Wireless MPG Frequency
Hello,
It does not say anywhere on them but they run in the 433 MHz ISM bands.
I found that out from taking one apart and measuring the antenna length, observing the communications with a spectrum analyzer, and from measuring the response of the antenna for the USB transceiver a year or two ago. I think I also found the part number for the transceiver inside the pendant but I cannot remember it right now.
Just to update for others. The frequency is 433Mhz at least the antenna I installed works with it. The antenna is specifically for 433 but may cover a wider band. Either way it works and has a very strong signal.
Thanks centroid467
Thanks centroid467
No problem! Happy to help!
