c:\cnct is CNC12 folder
c:\icn_lath is the Lathe Conversational folder (Intercon Lathe program)
Move to different hardware
Re: Move to different hardware
- CNC Control System Serial Number: 0035FF8A7F34-0730203594
So that only leaves c:\cncfiles. Is this intended as a storage folder for Gcode programs that you have created with intercon?
that folder is not a centroid provided folder i have no idea what it is.
are you confusing
c:\cnct\ncfiles ? that is the default location for G code. (but you can store g code where ever you want)
are you confusing
Thanks Keith, perhaps I created it for some reason, or made a copy from somewhere else as a backup. Anyway, I'll look at its contents and if they're irrelevant, I'll delete the c:\cncfiles copy.
