Closed loop stepper
scatgo
Closed loop stepper
Post by scatgo »
Just found this setup on Amazon. This is what I am going to use unless any of you had problems with this setup. It looks to me like I will need a power supply for each drive. I have no problem with that. Can someone please help me confirm they will work with Acorn. I just spent so much time looking at wiring diagrams I think my eyes are about to blow up. :shock: :? . Thank You
https://www.amazon.com/stepper-Controll ... 106&sr=1-5
Re: Closed loop stepper
Yes, those will work with Acorn. It's a standard close loop stepper. Those will wire to the DB25 so you'll also need to order a DB25 breakout board from Amazon as well.
Like this:
https://www.amazon.com/gp/product/B073R ... 1965d6ae5a
scatgo
Post by scatgo »
Thanks.
i moved this thread into the Acorn forum
