Big progress but stuck on the part below.
Is the tool offset library in the parm's?
I want to be able to read and write to them within a macro and not have to go into the library itself.
Is there a way?
Ken
Tool offset Help ??
Tool offset Help ??
Re: Tool offset library in param's ??
Tool offsets are not in the Machine Parameters table with Parameters 0 - 999.
Tool Offsets are accessible as CNC system variables, #10000 - #10200 and #11000 - #11200. See section 11.2.16 of the Mill operator's manual (page 193 in the 1/11/24 PDF version).
Tool offsets can also be set using the G10 code. See section 12.6 of the Mill operator's manual (page 237 in the 1/11/24 PDF version).
Figured out and fixed
Ken
