Hi,
I recently updateed to CNC12 v5.08 and noticed that when I set the feed rate to 25% the machine still jogged at 100%. What am I missing here?
Thanks.
Jog Speeds after Update to CNC12 V5.08
- report_E415F6F250EF-0205202948_2024-03-08_18-59-21.zip
- (911.22 KiB) Downloaded 2 times
- CNC Control System Serial Number: E062346A1C67-0716214939
Re: Jog Speeds after Update to CNC12 V5.08
The feed rate and rapid rate are separate now. Dialing back the rapid rate will affect your jog speed.
Thank you!
as AVP pointed out (thanks) in v5.08 jog speeds are linked to the rapid override.
We have changed that for v5.1 , in v5.01 jog speeds linked to the feedrate override controls
