New Build: Multiple machines
Hello all !
Also posted on Hickory...
I have a 5X-200 5 axis mill in with a damaged cpu. The machine is made by Doowan and is quite slick. It has Sigma 5 drives all run through CScam ethercat controls. Sycotec spindle and drive.
Not knowing much about ethercat, is there a standard protocol or are all parameters programmed to the specific machine.
It seems my options are...
Getting a new controller from CScam ( no luck so far.. )
Getting Centroid products to talk to the machine ?
Installing Acorn 6 and chucking the ethercat stuff, which is kind of a pity because the setup as it stands is pretty slick. I have all the mechanicals like gear ratios on two of the axes and ballscrew pitch on the others.
I have two other machines that need conversion, Colchester VS 15" lathe w/Fagor DRO and a Hitachi Seiki VM40.
Thoughts ? It would seem to make sense to do all with Acorn and use one controleer if possible.
gb
Top
gb
Top
Re: New Build: Multiple machines
What are the Yaskawa drive model numbers? The drives themselves probably support a number of other command signals.
Liviu is saying that our Oak controller will talk directly to the Sigma 5 units.
and if those same sigma 5 units also accept step and direction the AcornSix could run them as well. but we'd need to see model tag on the drives to find out.
Re: New Build: Multiple machines 5X-200
I managed to get a few pics in here, definitely won't win any photo awards !
https://photos.app.goo.gl/mcjHuZdhqb88xMT16
Re: New Build: Multiple machines :Hitachi Seiki VM40
I would do hickory on this one.ecaltd wrote: ↑Sat Mar 09, 2024 12:00 pm The VM40, Thinking OAK here as well ...
https://photos.app.goo.gl/BBcqgx4sSTEPZGBQ9
looks like a well built machine with yaskawa drives! AcornSix or Oakecaltd wrote: ↑Sat Mar 09, 2024 5:34 am I managed to get a few pics in here, definitely won't win any photo awards !
Re: New Build: Multiple machines: Triumph VS
what kind of servos does this lathe have?ecaltd wrote: ↑Sat Mar 09, 2024 12:01 pm Annnd ACORN 6 here
https://photos.app.goo.gl/sSYAnB7BXhtoYiPg7
got any over all shots of the machine? i can't the machine in the album
Hi Keith !
This one is old school manual, starting from scratch ;o)
