Homing 4th Axis
- CNC Control System Serial Number: 0035FF98CA2D-0813215079
Homing 4th Axis
Hello,
I have a homing switch for my A axis. How do I setup the homing of my rotary axis?
- report_0035FF98CA2D-0813215079_2024-03-06_22-53-50.zip
- (822.91 KiB) Downloaded 3 times
Re: Homing 4th Axis
confirm operation of rotary switch with the PLC I/o screen (alt i)
open the Wizard
- define the input that you have the rotary switch wired to as 4th axis Home Ok
- go to the homing menu , select Automatic Homing, double check the homing direction and order
- press write settings to cnc control
open the Wizard
Re: Homing 4th Axis
Thanks Keith. Once I get off work I will give that a shot and report back. Thanks again for the help.cnckeith wrote: ↑Thu Mar 07, 2024 2:23 pm confirm operation of rotary switch with the PLC I/o screen (alt i)
open the Wizard
Re: Homing 4th Axis
Hi Keith,cnckeith wrote: ↑Thu Mar 07, 2024 2:23 pm confirm operation of rotary switch with the PLC I/o screen (alt i)
open the Wizard
I finally got to follow your instructions. How do I hone the 4th axis?
Is there a manual command?
Re: Homing 4th Axis
If you followed Keith's instructions, the homing routine (cncm.hom) will have been created, and the homing command for the 4th axis will be in it. Then upon power up, when instructed to home the machine, it will automatically do it (if you have it set up correctly).
Scott
Re: Homing 4th Axis
Duh… got it. I was as thinking way too hard. I will look for the file to see the homing command.Sword wrote: ↑Tue Mar 12, 2024 11:50 pm If you followed Keith's instructions, the homing routine (cncm.hom) will have been created, and the homing command for the 4th axis will be in it. Then upon power up, when instructed to home the machine, it will automatically do it (if you have it set up correctly).
Thank you!
Re: Homing 4th Axis
The command on the bottom of the file is M26/A and when I type that in MDI and hit run nothing happens.Sword wrote: ↑Tue Mar 12, 2024 11:50 pm If you followed Keith's instructions, the homing routine (cncm.hom) will have been created, and the homing command for the 4th axis will be in it. Then upon power up, when instructed to home the machine, it will automatically do it (if you have it set up correctly).
Sorry for so many questions guys.
I appreciate the help.
Re: Homing 4th Axis
Hello,
I tried to home the machine and all axis home fine except for the A axis. A axis does not home.
I have attached a picture of, forgive me for the wood dust…
What am I doing wrong?
Re: Homing 4th Axis
There should be a M91/A or M92/A before the M26/A. Post a current report since your last changes to set up the A prox.
Scott
Re: Homing 4th Axis
Then report attached should be the most current one Scott.
Thank you!
