Greetings,
Our Multicam MG CNC router has been productively controlled by an Acorn board for the last 3 years. Last week I restarted it but after homing, the Z axis would not move using the wireless WMPG-4 or the VCP. I could only get movement using MDI. The X and Y axis were also demonstrating issues. They would only move at slow speed. Again, MDI, provided normal movement.
I first thought the issue might be the WMPG-4. A year ago I had a WMPG-4 fail and require replacement. I replaced the batteries to no effect. I then swopped it out with another working WMPG-4 from another machine. Still nothing.
The problem started after upgrading to CNC12 v5.06. I replaced the cncm file with its former CNC12 V4 versions. Still no solution.
Finally I changed out the entire Acorn board from another machine. This worked. All behavior is now normal. This is with CNC12 V5.08.
Has anyone else encountered a similar issue?
Z Axis lost control with VCP and WMPG-4
- CNC Control System Serial Number: 1218120647
- report_0035FF6335CA-0503191973_2024-02-19_10-32-31.zip
- (862.7 KiB) Downloaded 5 times
Re: Z Axis lost control with VCP and WMPG-4
is this report from the problem setup or?
The report was made when I was in the process of diagnosing the problem.
I didn't have a problem with my set up. The machine worked fastastic for 3 years. Worked well after upgrading to V5.06.
One morning control of the Z axis with the VCP or WMPG-4 stopped.
did you do a fresh install or use "restore" report? when installing v5.06
Sorry for my slow responses. We've been on site on an installation for the last two weeks.
I did a fresh install and rebuilt the system from Wizard PDFs I printed and I rebuilt my VCP using buttons and HTML files used previously.
v5.06 worked for a month or so before this issue occured.
Now that I'm back in the shop, I will reinstall the Acorn board that failed to see if the issue returns on it with v5.08.
