Wait for spindle
eman5oh
CNC Control System Serial Number: 20D77883F936-0629237375
Wait for spindle
Post by eman5oh »
I can't seem to figure out how to get the Acorn to wait for my spindle to spin up to speed before cutting. I was able to work around it for now by adding a G4 P10 to the file but would like it to be automatic. I have the VFD at speed wired to input 5 and have watched the PLC to see that input 5 works as it should, how do I get the acorn to wait for this input before cutting?
report_98F07B6F8180-0629237365_2024-03-03_20-54-25.zip
(926.77 KiB) Downloaded 3 times
Re: Wait for spindle
Add the dwell or delay in your M3 macro after the spindle turns on. This way it'll be sort of "automatic" every time you call the M3 to turn the spindle on. Just add your G4 P10 as the last line.
That said, 10 seconds is an eternity for a spindle to spin up. :mrgreen: Maybe adjust your acceleration time in your VFD parameters.
Search for recent threads on this. A recent post by Marc explains how to add a test in the M3 macro to check for the spindle up to speed signal.
Muzzer
Post by Muzzer »
Presumably this one https://centroidcncforum.com/viewtopic. ... 578#p41578
How to use M101 - this is from the lathe manual but I assume it's valid for mill too:
use the "up to speed" input, no need for any custom plc programming work.
example wiring of this.
https://www.centroidcnc.com/dealersuppo ... 223.r1.pdf
cnckeith wrote:use the "up to speed" input, no need for any custom plc programming work.
Are you sure that his Acorn-standard PLC program or M3/M4 macros will do anything with that input?
Looking at the 12/11/2023 AcornSix template (the only one I have immediately handy) I see where "VFDUpToSpeed" is defined, but I don't see any place where it is used. Maybe the basic Acorn program is different?
i'll check, maybe it didn't get commited.
just add the m101 to look at this input in your mfunc3.mac
eman5oh
Post by eman5oh »
cnckeith wrote: Mon Mar 04, 2024 7:58 pm i'll check, maybe it didn't get commited.
I am pretty sure it does not wait, I have input 5 setup with that signal and can see the VFD is setting it proper once the spindle is spun up, the acorn is not however waiting for it. I'll edit the mfunc3.mac and mfunc4.mac too?
yes you edit m3func.mac and m3func.mac and tell it to wait for the input that you have assigned as "VFD up to speed" as.
macro editing guide.
https://www.centroidcnc.com/centroid_di ... amming.pdf
eman5oh
Post by eman5oh »
cnckeith wrote: Mon Mar 04, 2024 8:09 pm yes you edit m3func.mac and m3func.mac and tell it to wait for the input that you have assigned as "VFD up to speed" as.
It worked after I added M101/50005 to the M3 macro, it did not work with just input 5 defined as vfd up to speed. Next up is to add the Rapid Change ATC, pretty excited to give that try!
