I got a percision mathews 932v with an acorn set up i have 3 limit switches 1 on each travel. I have set the soft limits i think but i can still crash it if i follow this video it lock me out on movement.
I want to stop all possibilities of crashing
This is 1 video i tryed
Help
Re: Help
Cory, please post a current report from your machine so that we may see your settings and help you more.
If you have 3 "limit" switches set up then it's not setup correctly. There is a difference between a HOME switch and a LIMIT switch. We need to know if you have mechanical or proximity switches. NO or NC? Please share a link to a google album with pics of the machine. We need A LOT more info to help you.
Guidelines for asking questions on the forum, we simply need more info.
https://centroidcncforum.com/viewtopic.php?p=5010#p5010
Re: Help
Thanks for the response shawn, im new to this all i bought a machine from a company that was ro be ready to go and the seller has ghosted so trying to add the missing pices in. I can home the machine in start up it all 0s out like i want i do beleave head lifts till it hits switch and stops y axis comes towards you till it stops and the x moves till sensor touches and it stops but its the other side of the axis i want to controle to stop so thay it does not keep going
Im.out of town so i can only post photos i have of the machine as you can see in photos the style of sensors i have and placement
Re: Help
Ill definitely have to get kore info if that does not work as i did not know all that information was needed or there to help
Re: Help
When you get back post a current report from the machine and we'll get it going. You said you "think" you set the soft limits but if you can crash it in either direction something is not set right. Sounds like you may have a couple of settings mixed up. Easy enough to fix.
Re: Help
i moved this post out of the "machining strategies" forum into the Acorn Forum
