Higher resolution on Wmpg encoder wheel
Is there a way to get less movement of an axis when using the knob on the wmpg? I would like it not to move as much when I have it on the 1x setting. I have the 1x setting in the wizard set at .001 or what ever it say on the pop up is the lowest number it can be. I am using MM.
Re: Higher resolution on Wmpg encoder wheel
.001 mm? per click. wow that is small number. what kind of machine is this?
