I would be interested in seeing it work. I am in initial stages of setting up a cnc lathe and will need to know more about tool setting. I've used a coaxial indicator on a mill where I have X and Y However on a lathe i'm guessing that shimming may be required for tweaking vertical adjustmentPhilipTrueman wrote: ↑Fri Jan 26, 2024 3:45 pmIt is called a coaxial indicator in English.suntravel wrote: ↑Fri Jan 26, 2024 3:39 pm I am using this for drills:
https://www.hogetex.de/zentriergerat-vc ... Q0QAvD_BwE
Setting lathe tools with a touch probe V5.08
Re: Setting lathe tools with a touch probe V5.08
If you have a lantern style tool post, you adjust tool height with packing. Most quick change tool posts (QCTP) have height adjustments.
I just tried to use the coaxial indicator but there isn't enough Z travel to fit one in between the chuck and the turret.suntravel wrote: ↑Fri Jan 26, 2024 3:39 pm I am using this for drills:
I will have to use a small dial test indicator.
Excellent idea. Nice work Uwe. I will have to make one of those.
Could you do a video please Uwe? Your videos are precise and to the point, you could educate some lesser beings!
Cheers
Cheers
Excellent, will look forward to it as I use the same probe as yours.........
