today i drafted a discussion paper on tool height offset methods
Re: today i drafted a discussion paper on tool height offset methods
Ken Rychlik wrote: Thu Apr 11, 2024 3:12 pm Will the new version auto store the tool offset in the library? I changed to z zero button to Z Reference so my brain understands.
I
Ken
im not sure what you mean. Reference in our lexicon is not a part zero.
any version of CNC12 will "auto store" the tool offsets, this is nothing new. :D
Ken Rychlik
Post by Ken Rychlik »
Ken
I couldn't use the auto measure feature with my table limits, so maybe that would be fixed together.
I want a macro button on screen for measuring tools instead of going into the library, so maybe that's on me. Could a macro button access the auto measure in the library maybe?
I am to lazy to want to click sever buttons to get into the library to do what I think one button should do.
I even like a button to fire up the dust collection and have it sweep the table clean between sheets. When you use one to make a living for a long period of time, the little things are important.
Ken
Houseman303
CNC Control System Serial Number: A901313
Post by Houseman303 »
For me, Z Reference would be Tool 0 (empty spindle). Every measured tool is a positive value that can also be remeasured. Compatible with external tool setters. Values ​​of D and H from the active tool on the main page during program run would be fantastic.
The "Reference Tool" is the tool, real or imaginary, that is the standard length against which all the other tools' length offsets are measured.
"Z Reference" is the head position (Z axis DRO reading) at which the Reference Tool touches the surface that you are going to measure tools upon.
Yes, if your Reference Tool is the face of the empty spindle, then every real tool will have a positive offset.
That positive offset is determined by subtracting the Z axis position at which the real tool touches the measuring surface, from the Z Reference position at which the reference tool touched the measuring surface.
spikee
Post by spikee »
In LCNC i used tool 99 as the reference tool. in my case it was the nose of the spindle (without holder). For centroid it would be the same.
