Quick Tip: Centroid Software Diagnostic Screen
Posted: Sun Aug 20, 2017 12:11 pm
Reminder, there is a very helpful screen in the Centroid software that lets you check the status of the Inputs and Outputs. Useful during setup and testing of your machine.
From the main software screen, press ALT-I
You will see the diagnostic screen with "LED"s. The ones you are interested in for Acorn will be the first 8 inputs on the top line far left and the next line down are the outputs, same thing, first 8 on the left.
You can "TEMPORARILY" invert the input by pressing CTL+ALT and I to invert the input. I suggest you only use for testing purposes only.
You can use your arrow keys to move the "box" around the input you are interested it. About the middle of the screen, just under the last row of "LEDs" will be a descriptor of the Input/Output you have the selection box around.
