If there's already a post for this please point me there.
I really hope this makes cents....
My machine is setup and using the rack mount ATC using Holes. My tool library isn't updating properly with the right tool bin when doing a T01 M6. If I use the Menu (Setup->ATC) button it works fine. It will mess up in a program and MDI. It seems to be the macro but I'm not an expert with macros on this controller. I've included my M6 macro for reference. It will update the Para. #976 with where it pulled the tool from. Problem is it updates the tool library bin with what ever tool is called next. So if I want T0303 in Bin 003 it will get it and then I need T0404 in bin 004 it will get it but will add T0303 to the same bin (004). It will work so long as I don't want the same tool again later. Here's a better example:
T01 B001
T02 B002
T03 B003
I can call and retrieve all these tools in any order but when I need to reuse a tool the bin #s are behind
Call T01 -> T02 -> T03
The bin #s now will be as follows:
T01 B002
T02 B003
T03 B001
It seems to me the library bin is being updated with the bin# that is next called and not where it was put.
Any help would be great!
ATC Bug M6 Macro issue <resolved>
- report_E06234830BF4-0624226370_2023-09-28_15-02-14.zip
- (899.51 KiB) Downloaded 3 times
- mfunc6.mac
- (10.29 KiB) Downloaded 7 times
Re: ATC Bug M6 Macro issue
Hello!
This does appear to be an issue, It looks like the cause is possibly lookahead reaching the end of the M6 macro and assigning putback for the bin before it was updated by P976 and PLC.
Attached, i have a modified M6 that should correct this issue for you. Will of course also be included in the next revisions of the software. To Install, simply place it in your C:\cncm directory and overwrite the current mfunc6.mac file.
You may want to set "using custom M6" macro in the wizard otherwise the wizard may blow away my changes for the time being as well.
Let me know if this corrects your issue.
- mfunc6.mac
- (10.46 KiB) Downloaded 13 times
Centroid PLC Tutorial Videos
Thanks so much. I’ve updated my macro with the one you shared. It’s been working smooth for the past two days.
