Probably over thinking this, but...
If I have a supply cord to my machine with a ground in it and the Acorn is connected to that ground. Then I have a separate supply cord to the CNC PC, also with a ground. Both go back to the consumer panel, but to different breakers.
When I connect the shielded ENet cable between the CNC PC and the Acorn, doesn't that create a ground loop back to the panel?
I have confirmed the Acorn RJ-45 connector is connected to V- and the CNC PC is also connected to V-. Should/can I remove the shielded RJ-45 connector at one end of the RJ-45 cable and replace it with a non-shielded one?
Or is this a non-issue?
Grounding question
- CNC Control System Serial Number: 20D7787C45AB-0819226470 - 98F07B6F97F8-0623237343
Grounding question
Thx
Ian
Ian
Re: Grounding question
Non issue
Cool, thx Gary.
Thx
Ian
Ian
