Good afternoon!
I'm using CNC Pro Router on Acorn board. I've been running CNC12 V5.06 for about five weeks now. I'm new to Centroid CNC but it seems to be a fantastic platform to grow and learn on. Can anyone help me figure out how to access the Primary System Tab in the Configuration Wizard? When i setup my system the Axis Drive Type, Input Definitions and Output definitions were all accessible. Now they are not. They are grayed out and i cannot select any of those three options.
I've searched the web but have not been able to find any topics relative to my issue. Forgot about this support forum.
Thanks in advance!
Cannot access Primary System Tab in Configuration Wizard
Re: Cannot access Primary System Tab in Configuration Wizard
Did you select Custom PLC in the Wizard?
- CNC Control System Serial Number: C16442
Uwe,
Thanks! Yes, that was the case. I do not remember selecting but i guess that i did. I was able to deselect this option is wizard and save. Unfortunately, each time i restarted the application and looked at the options in wizard, the Custom PLC was selected in the Wizard options. Ultimately I had to uninstall and reinstall the CNC12 V. 5.06 application.
Thanks for the assistance!
Eddie
Eddie
